PWB.EXE has generated errors and will be closed by windows :
Chartway
Post by Chartway »
I get the following error when I click on any link, or type in any URL into PWB.
I am running Windows 2000 with SP2.
I have CHECKURLACCESS=TRUE.
I keep my URL.TXT file in C:\CONFIG and have specified that path in the INI file.
I can't get past my home page. if I set CHECKURLACCESS=FALSE then it works fine.
Chartway
Nevermind :)
Post by Chartway »
I had CHECKURLFILE=c:\config\url.RTF
Could you ask something do that if it can't find the config files it puts up an message like "incompatable config file or config file not found at location specified in PWB.INI" or something like that.
Chartway
OMG Spelling
Post by Chartway »
I really should check my spelling before I hit submit.
You are absolutely right, I will add it to our to-do list. Thanks for the sugestion.
As of 10-14-03, PWB v2.03 revision 1 contains better file checking and pathing. PWB adds the PWB path to the file if a path is not specified, and checks for the existence of the file and give a warning if it is not found.
