AIM Express
jfrasier
AIM Express
Post by jfrasier »
We are using PWB 2.09. When a user goes to aim.com and tries to use AIM express, they logon, a window puts up for the buddy list, but it is never filled in.
What could be causing this?
Jane
I would try upgrading to PWB v2.10. If this does not solve the issue, please send a copy of your INI file to support@teamsoftwaresolutions.com.
It works with PWB v2.10 with a stock INI file.
jkowal5
Any other responses to this?
Post by jkowal5 »
We are having the same issue and we are using version 2.10. I tested AIM Express using IE7 on the same computer and had no problem, but with PWB, you just get a blank buddy list window that seems to be loading, but nothing more happens. Is anyone else having this problem, or has anyone figured out how to correct it? Thanks!
We are currently working on fixing the problem with PWB and AIM Express.
You may also want to take a look at WinBatten. This application allows you to control Internet Explorer itself almost as much as you can with PWB.
