History File Token Code
General TSS software questions and comments.
Here is a list of the codes PWB uses in the history file.
<-> Normal, URL entered in Address box
<p> Page Printed
<e> PWB error occurred
<t> URL Tracking, TrackURL=True
<a> Access logging, LogAccess=True
<a-> Access string was denied
<a+> Access string was allowed
<a;> Access string was not found
<ad> Pop-up closed, ClosePopupAds=True
<d> Access string denied, LogDeniedAccess=True
<ur> Pop-up closed, DisableUnrequested=True
<a=> Execute Access allow download
<a#> Execute Access navigate to file
<a!> Execute Access open in application specified
The history file has many levels at which it writes so you can control the amount of information that is written.
HistoryFile=History.txt
Enables History file and writes all URLs entered in the Address bar.
LogAccess=True <a-> <a+> <a;> <ad>
Causes PWB to write to the history file when access for the IP, URL, and POPUP, filters are used.
<ad> Popup ad is being checked
TrackURL=True <t>
Causes PWB to write to the history file when any URL is browsed to.
CheckURLAccess=False
CheckIPAccess=False
ClosePopupAds=False
Used with log access if the history file is enabled.
To limit the history file, you should have TrackURL and LogAccess set to False.
Jaysun
Provider
Provider
Post by Jaysun »
What does <a*> mean in the history file?
Jason
Jason Weinstein
Application Support Technicain
Eugene Public Library
Eugene, OR
The "<a*>" means PWB check for access on the URL and did not find any matching strings in the filter file so it is taking the default action supplied in either the "+all" or "-all" option.
timh
Re: History File Token Code
Post by timh »
... and <d> ? (which always seems to follow an <a*> for the same URL in my logs).
Tim
Tim,
The information has been updated.
boby
Spectator
Spectator
Post by boby »
Run administration activity reports...these will show when serial number was assigned to userid.
Get the latest home decor ideas and crafting tips. Buy best home decoration & kitchen accessories, bathroom accessories online here.
