Unistalling
Unistalling
Post by Guest »
Can someone tell how to unistal Public Web Browser. I downloaded it and have tried it, but it doesn't have some off the features I am looking, such as Tabs for multple pages.
When I went to Add/Remove I was surprised to find that there is no uninstaller.
Bert Hibberd
Australia
User avatar
Philip - Long Beach NY
Post by Philip - Long Beach NY »
Are you sure you downloaded the MSI installer and not the upgrade or Manual Install?
If you're sure, what O/S are you using?
If you downloaded the manual install I believe all you have to do is delete the INI and EXE files but I'm not 100% sure.
Scott?
--Philip
-- Steve Gibson
If you used the installer, go to the Control Panel and use the Add/Remove Programs applet.
If you did a manual install, just delete the PWB folder. PWB also creates a couple of registry keys, use regedit to delete the following.
HKLM\Software\TeamSoftware Solutions
HKCU\Software\TeamSoftware Solutions
