PWB 2.11 and Yahoo attachment
- Participant
We are running PWB on our machines for public use. As far as I know it is installed on the clients and fetches the settings from a server. So the problem is the PWB when it loads yahoo mail it comes up with the whole upgrade your browser thing. You can by-pass this but then it does not enable the attachment Icon for yahoo mail (not even loaded in to the screen). Any ideas
Re: PWB 2.11 and Yahoo attachment
PWB uses the currently installed Internet Explorer on the computer PWB is running on, make sure you are using at least Internet Explorer 10.
- Participant
We are using the most current one. That is not the issue. If I run just IE the attachment icon show up. If I run the PWB layover it goes away
Ensure you do not have PWB setup to use Internet Explorer Compatibility mode.
The following line should be removed or set to blank.
IEBrowserEmulation=
See attached.
IEBrowserEmulation=
See attached.
- yahoo.png (138.92 KiB) Viewed 24116 times
- Participant
Changed the setting in the INI file. It was previously set to 9000 it is now blank.
This is what we have in the INI file if you want to look at it
RegisteredTo=*************************
RegistrationNumber=************************
IniFileVersion=2.11
Title=Public Web Browser
KioskMode=FALSE
DesktopMode=FALSE
HomePage=http://www.iredell.lib.nc.us/public/default.html
CommandLineHomePage=FALSE
SearchPage=
WebMailPage=
AddressBarText=Web Address:
DefaultFontSize=2
DefaultSendLink=TRUE
StartMaximized=FALSE
AlwaysOnTop=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
ShowMenuBar=FALSE
ShowToolBar=TRUE
ShowShellBar=FALSE
ShowAddressBar=TRUE
ShowAnimation=TRUE
ShowStatusBar=TRUE
ShowTitleBar=TRUE
ShowBackButtonMenu=FALSE
ShowInactivityTimer=FALSE
ShowActivityTimer=FALSE
ShowStatusBarTime=FALSE
ShowURLInBrowserCaption=TRUE
DisableMinimizeButton=FALSE
DisableMaximizeButton=FALSE
DisableCloseButton=FALSE
DisableMoveWindow=FALSE
DisableResizeWindow=FALSE
DisableNewWindow=FALSE
DisableINIVersionCheck=FALSE
DisableExit=FALSE
ConfirmClose=FALSE
UseIEFavorites=FALSE
ShowGoButton=TRUE
GoButtonText=Go
AlwaysOnBottom=FALSE
ShellButtonIconWidth=
ShellButtonIconHeight=
DisableIESubClass=FALSE
ShowWindowRelation=FALSE
MainWindowIndicator=
ShowKioskBar=FALSE
F1HelpPageURL=
ShowSplashScreen=FALSE
DisableAutoComplete=TRUE
ShellExecuteScripts=FALSE
OpenLinksInNewWindow=FALSE
DisableCtrlEnter=FALSE
IEBrowserEmulation=
ShowAddressInBrowserCaption=FALSE
ShowSearchBar=TRUE
SearchBarText=Search
SearchBarPage=http://www.google.com/search?q=%SEARCH%
ConfigRegLocation=
SaveWindowPosition=FALSE
MinimizeMemoryUsage=FALSE
StartTimersOnMouseKeyboard=FALSE
AddStationToUserAgent=FALSE
UpdateWindowOnTime=FALSE
RedrawWindowSeconds=-1
EnableAdvancedClose=FALSE
DisableScrollBars=FALSE
MapContextPrintToButton=FALSE
PreventHTMLClosingMainWindow=FALSE
AddressBarReadOnly=FALSE
MaximizeOnNonsizeable=FALSE
SecureMode=FALSE
HideCursor=FALSE
ExitPage=
StatusBarTimeFormat=
StatusBarTimeWidth=32
DefaultZoomLevel=100
JavaScriptVoidCancelNavigate=False
[SecondWindow]
AlwaysOnTop=FALSE
LimitCount=-1
DisableTitleBar=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
NewPageAsHome=FALSE
OpenInParentWindow=FALSE
DisableUnrequested=FALSE
StartOnDesktopMode=FALSE
OpenDesktopModeLink=FALSE
ShowTimers=FALSE
ShellBarURLNewWindow=FALSE
ShowShellBar=FALSE
StartMaximized=TRUE
CloseChildrenOnClose=FALSE
SecondWindowIndicator=
OpenInNewProcess=FALSE
ShowAddressBar=TRUE
ShowGoButton=TRUE
ShowKioskBar=FALSE
ShowToolBar=TRUE
ShowMenuBar=FALSE
ShowStatusBar=TRUE
DisableShiftClick=FALSE
OpenInFrame=
ForceToFront=FALSE
ShowSearchBar=TRUE
[ToolBars]
MenuBarGripper=FALSE
ToolBarBreak=TRUE
ToolBarGripper=FALSE
ToolBarChevron=FALSE
ShellBarBreak=FALSE
ShellBarGripper=FALSE
ShellBarChevron=FALSE
AddressBarBreak=TRUE
AddressBarGripper=FALSE
MenuBarWidth=0
ToolBarWidth=0
ShellBarWidth=0
AddressBarWidth=0
GoButtonGripper=FALSE
GoButtonBreak=FALSE
AlignBottom=FALSE
KioskBarScrollBy=40
AutoSizeButtons=FALSE
ButtonTextRight=FALSE
SearchBarGripper=FALSE
SearchBarWidth=100
ToolBarIconHeight=0
ToolBarIconWidth=0
ShellButtonIconWidth=0
ShellButtonIconHeight=0
KioskToolBarIconHeight=-1
KioskToolBarIconWidth=-1
KioskBarButtonColor=
KioskBarBackGroundColor=
SearchBarBreak=FALSE
[Printer]
ShowPrintButtonDialog=FALSE
ForcePrintPreview=TRUE
UseLimitPrintJobs=FALSE
LimitPrintJobs=0
PrintJobLimitTitle=Print Limit
PrintJobLimitMessageFile=PrintLimit.txt
ShowPrintingDialog=FALSE
PrintingTitle=Page Printing
PrintingMessageFile=Printing.txt
CheckPrintAccess=FALSE
PrintDialogShowCancel=TRUE
ShowPrintMenuDialog=TRUE
PrintTemplateFile=
ShowPrintIDDialog=FALSE
PrintIDDialogTitle=Print Identification
PrintIDDialogHeight=0
PrintIDDialogWidth=0
PrintIDDialogFile=
AddSystemMenuPrint=FALSE
[Dialogs]
DialogSeconds=15
PolicyTitle=Policy
AccessTitle=Warning: Denied
ConfirmCloseDefaultNo=TRUE
ConfirmCloseTitle=Confirm Close
PolicyHeight=768
PolicyWidth=1024
ConfirmCloseSoundFile=
AccessDeniedSoundFile=
AlwaysOnTop=TRUE
SecondInstanceTitle=Second Instance
IncorrectPasswordMessage=Incorrect password entered?!
AccessURLRedirect=
PolicyShowDecline=TRUE
PolicyShowClock=FALSE
MessageHeight=0
MessageWidth=0
OkButtonText=Ok
CancelButtonText=Cancel
DeclineButtonText=Decline
AcceptButtonText=Accept
YesButtonText=Yes
NoButtonText=No
ShowPopupMessage=FALSE
PopupOnMessageTitle=Pop-ups are on
PopupOffMessageTitle=Pop-ups are off
UseHtmlDialogs=FALSE
MessageTop=0
MessageLeft=0
DisableCloseButton
WorkingAnimation=
PolicyFile=\\icpl-dc00\pwb\Policy.rtf
HistoryFile=history.txt
CheckURLFile=URL.txt
CheckIPFile=IP.txt
PopupAdFile=Popup.txt
AccessMessageFile=Access.txt
ConfirmCloseMessageFile=
SaveAsErrorMessageFile=
FavoritesFolder=Favorites
ShellBarFolder=ShellBar
StartupScript=
ShutdownScript=
PolicyDeclineScript=
DesktopFile=
SendToApp=
SecondInstanceFile=
ToolBarButtons=
CheckPrintFile=
PopupOnButtonFile=
PopupOffButtonFile=
PasswordFile=
KioskBarButtons=
NewWindowProcessINI=
InactivityScript=
AlwaysOnTop=True
SendToAppFile=
SendToAppLink=
CheckPostDataFile=
CheckACFile=
ActivityScript=
TimeCheckScriptDay=
TimeCheckScriptNight=
ToolBarIconFolder=
[WebFiles]
EnableWebFiles=FALSE
CheckURLFile=http://www.teamsoftwaresolutions.com/WEBURL.txt
CheckIPFile=
CheckPrintFile=
PopupAdFile=
[Directories]
SaveAsDirectory=%USERPROFILE%\%USERNAME%\desktop
SaveAsErrorTitle=Floppy required
DownloadDirectory=%USERPROFILE%\%USERNAME%\desktop
DownloadErrorTitle=Floppy required
[RestrictedSave]
EnableRestrictedSave=False
RestrictedSaveApp=
UseUniqueHistoryFiles=FALSE
WriteHistoryFile=FALSE
TrackURL=FALSE
CheckURLAccess=FALSE
CheckIPAccess=FALSE
ClosePopupAds=FALSE
ShowAccessDialog=TRUE
LogAccess=FALSE
ClearCacheOnHome=FALSE
ClearCacheOnClose=FALSE
DisableAddressDropDown=FALSE
DisableContextMenu=FALSE
UseCustomContextMenu=TRUE
ShowPolicyDialog=True
OnlyAccessHTTP=TRUE
DisableSecondInstance=FALSE
RestartOnClose=FALSE
ShowPasswordDialog=FALSE
PasswordTitle=Public Web Browser
Password=password
CheckInitialURL=FALSE
DisableFileDownload=FALSE
EnableFileDownload=TRUE
AllowSingleLinkLevel=FALSE
AllowBrowseOnDeny=FALSE
LogoffOnExit=FALSE
ShowFilterStatus=FALSE
FilterOnText=<Filter On>
FilterOffText=<Filter Off>
ShowProxyStatus=FALSE
ProxyOnText=<Proxy On>
ProxyOffText=<Proxy Off>
ShowDenyDialogOncePerSession=FALSE
OnlyAccessInternet=TRUE
DebugAccessString=FALSE
AllowLinkLevelDepth=3
RestrictFileDownload=False
CheckPostDataAccess=FALSE
DisableFileUploads=FALSE
TrackLogon=FALSE
CacheFilterFiles=TRUE
CheckACAccess=FALSE
SecondInstanceNavigateCurrent=FALSE
RebootOnExit=FALSE
PreventFileDownload=FALSE
EnableAlternateOverrideKeys=FALSE
LogDeniedAccess=FALSE
EnableFilterOrLogic=FALSE
[Overrides]
ExitBrowser=
Logoff=
Shutdown=
ResetActvityTime=
ResetPrintLimit=
RestrictedSave=
ReReadINIFile=
OpenSysedit=
OpenRegedit=
OpenExplorer=
DisableProxy=
DisableFilters=
ShowAddressBar=
OverrideURLKeyword=
[Java]
JavaExit=
JavaActivity=
JavaRegister=
JavaHideToolbar=
JavaExecute=
JavaReadINIFile=
JavaPrint=PWBPrint
EnableExternalJava=TRUE
JavaRegistryRegister=
JavaLogoff=
JavaReboot=
JavaShutdown=
JavaHideAddressBar=
JavaPrintFrame=
JavaFillElement=
JavaOverrides=
JavaStartApp=
JavaSetActivity=
JavaGetActivity=
[ScreenSaver]
EnableScreenSaver=FALSE
ScreenSaverSeconds=1200
EnablePolicyScreenSaver=FALSE
PolicyScreenSaverSeconds=10
DisableScreenSaverOnPolicyClose=FALSE
DisableScreenSaverOnClose=FALSE
WindowsScreenSaverExe=
WindowsScreenSaverMinutes=0
InactivitySeconds=1200
InactivityMessageTitle=Warning
InactivityMessageFile=Inactivity.txt
InactivityAction=Home
InactivitySoundFile=
InactivityStartOnOpen=FALSE
InactivityShowDialog=TRUE
ResetOnMouseMove=TRUE
ResetOnMouseButton=TRUE
ResetOnKeyboard=TRUE
[Activity]
ActivityTimer=FALSE
ActivitySeconds=1200
ActivityMessageTitle=Warning
ActivityMessageFile=Activity.txt
ActivityWarnAt=120
ActivityWarnTitle=Warning
ActivityWarnMessageFile=ActivityWarn.txt
ActivityAction=Exit
ActivitySoundFile=
ActivityStartOnOpen=FALSE
ActivityShowInTitleBar=FALSE
ActivitySecondWarnAt=5
ActivitySecondWarnMessageFile=ActivityWarn.txt
DisableDialogTimer=FALSE
[Proxy]
UseCustom=FALSE
ProxyEnable=FALSE
ProxyServer=
ProxyOverride=
AutoConfigURL=
[PageSetup]
UseCustom=FALSE
Footer=&u&b&d
Header=&w&bPage &p of &P
MarginBottom=0.75000
MarginLeft=0.75000
MarginRight=0.75000
MarginTop=0.75000
Duplex=1
Orientation=1
[Buttons]
Back=TRUE
Forward=TRUE
Separator1=FALSE
Stop=TRUE
Refresh=TRUE
Home=TRUE
Separator2=FALSE
Search=FALSE
Favorites=FALSE
Print=FALSE
PrintPreview=Print
Separator3=FALSE
Send=FALSE
WebMail=FALSE
TextSize=TRUE
Zoom=TRUE
Separator4=FALSE
About=TRUE
Policy=TRUE
Separator5=FALSE
New=FALSE
Save=FALSE
Separator6=FALSE
Cut=FALSE
Copy=FALSE
Paste=FALSE
Find=FALSE
Encoding=FALSE
Popup=FALSE
Shell=FALSE
[MenuItems]
FileMenu=TRUE
FileNew=FALSE
FileOpen=FALSE
FileSaveAs=FALSE
FileSeparator1=FALSE
FilePageSetup=TRUE
FilePrintPreview=Print
FilePrint=FALSE
FileSeparator2=FALSE
FileSend=FALSE
FileSendFile=FALSE
FileSendLink=FALSE
FileSeparator3=FALSE
FileProperties=FALSE
FileExit=TRUE
EditMenu=TRUE
EditCut=TRUE
EditCopy=TRUE
EditPaste=TRUE
EditSeparator1=FALSE
EditSelectAll=TRUE
EditSeparator2=FALSE
EditFind=TRUE
ViewMenu=TRUE
ViewToolbar=True
ViewStatusBar=True
ViewSeparator1=TRUE
ViewGoto=TRUE
ViewGotoBack=TRUE
ViewGotoForward=TRUE
ViewGotoHome=TRUE
ViewGotoSearch=TRUE
ViewStop=TRUE
ViewRefresh=TRUE
ViewTextSize=TRUE
ViewTextSizeLargest=TRUE
ViewTextSizeLarge=TRUE
ViewTextSizeMedium=TRUE
ViewTextSizeSmall=TRUE
ViewTextSizeSmallest=TRUE
ViewSeparator2=FALSE
ViewSource=FALSE
ShellMenu=FALSE
FavoritesMenu=FALSE
FavoritesAdd=TRUE
FavoritesOrganize=TRUE
FavoritesSeparator=TRUE
HelpMenu=TRUE
HelpPolicy=TRUE
HelpAbout=TRUE
ViewZoom=
ViewZoomIncrease=Increase Ctrl+
ViewZoomDecrease=Decrease Ctrl-
ViewZoomLarge=Large
ViewZoomNormal=Normal
ViewZoomSmall=Small
ViewZoomCustom=Custom
ViewEncoding=TRUE
[ContextMenu]
OpenLink=TRUE
OpenLinkNew=TRUE
SaveTarget=FALSE
PrintTarget=FALSE
Separator1=FALSE
ShowPicture=TRUE
SavePicture=FALSE
SetWallPaper=FALSE
SetDeskTopItem=FALSE
Separator2=FALSE
Cut=TRUE
Copy=TRUE
CopyShortcut=TRUE
Paste=TRUE
Separator3=FALSE
Encoding=FALSE
Separator4=FALSE
Print=TRUE
Refresh=TRUE
Separator5=FALSE
Properties=FALSE
Back=Back
Forward=Forward
Separator0=TRUE
[URLKeys]
EnableURLKeys=FALSE
EnableURLFKeys=FALSE
[AutoRegister]
RegisterKey=***************
RegisterPassword=**************
RegisterSeconds=15
RegisterShowWindow=FALSE
RegisterDaysLeft=30
UseWindowsRegistry=FALSE
RegisterDelayClose=FALSE
[TimeCheck]
EnableTimeCheck=FALSE
TimeToActionDay=
TimeToActionNight=
TimeToWarnSeconds=300
ActionDay=
ActionNight=
MessageTitleDay=Day Action
MessageFileDay=
MessageTitleNight=
MessageFileDNight=
MessageTitleWarnDay=Day Warning
MessageFileWarnDay=
MessageTitleWarnNight=
MessageFileWarnNight=
[KioskButtons]
Back=TRUE
Separator1=TRUE
Forward=TRUE
Separator2=TRUE
Stop=TRUE
Separator3=TRUE
Refresh=TRUE
Separator4=TRUE
Home=TRUE
Separator5=TRUE
Print=TRUE
Separator6=TRUE
TextSize=FALSE
Separator7=TRUE
ScrollUp=TRUE
Separator8=TRUE
ScrollDown=TRUE
Separator9=FALSE
Close=TRUE
[HTMLError]
EnableRedirect=FALSE
DebugErrorNumber=FALSE
IniFileVersion=2.11
KioskMode=FALSE
DesktopMode=FALSE
SearchPage=
WebMailPage=
DefaultFontSize=2
AlwaysOnTop=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
ShowMenuBar=FALSE
ShowToolBar=TRUE
ShowShellBar=FALSE
ShowAddressBar=TRUE
ShowAnimation=TRUE
ShowStatusBar=TRUE
ShowTitleBar=TRUE
DisableExit=FALSE
ConfirmClose=FALSE
ShowGoButton=TRUE
GoButtonText=Go
ShowKioskBar=FALSE
F1HelpPageURL=
IEBrowserEmulation=
ShowSearchBar=TRUE
ConfigRegLocation=
SecureMode=FALSE
HideCursor=FALSE
ExitPage=
[SecondWindow]
AlwaysOnTop=FALSE
LimitCount=-1
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
NewPageAsHome=FALSE
ShowTimers=FALSE
ShowShellBar=FALSE
StartMaximized=TRUE
ShowAddressBar=TRUE
ShowGoButton=TRUE
ShowKioskBar=FALSE
ShowToolBar=TRUE
ShowMenuBar=FALSE
ShowStatusBar=TRUE
OpenInFrame=
ForceToFront=FALSE
ShowSearchBar=TRUE
[ToolBars]
ToolBarBreak=TRUE
ShellBarBreak=FALSE
MenuBarWidth=0
ToolBarWidth=0
ShellBarWidth=0
AddressBarWidth=0
GoButtonBreak=FALSE
AlignBottom=FALSE
KioskBarScrollBy=40
SearchBarWidth=100
ToolBarIconHeight=0
ToolBarIconWidth=0
[Printer]
LimitPrintJobs=0
PrintTemplateFile=
PrintIDDialogFile=
[Dialogs]
DialogSeconds=15
PolicyTitle=Policy
PolicyHeight=768
PolicyWidth=1024
AlwaysOnTop=TRUE
AccessURLRedirect=
MessageHeight=0
MessageWidth=0
OkButtonText=Ok
YesButtonText=Yes
NoButtonText=No
MessageTop=0
MessageLeft=0
DisableCloseButton
WorkingAnimation=
CheckIPFile=IP.txt
StartupScript=
ShutdownScript=
DesktopFile=
SendToApp=
SecondInstanceFile=
ToolBarButtons=
CheckPrintFile=
PopupOnButtonFile=
PopupOffButtonFile=
PasswordFile=
KioskBarButtons=
InactivityScript=
AlwaysOnTop=True
SendToAppFile=
SendToAppLink=
CheckPostDataFile=
CheckACFile=
ActivityScript=
TimeCheckScriptDay=
ToolBarIconFolder=
[WebFiles]
CheckIPFile=
CheckPrintFile=
PopupAdFile=
[Directories]
[RestrictedSave]
RestrictedSaveApp=
TrackURL=FALSE
CheckIPAccess=FALSE
ClosePopupAds=FALSE
LogAccess=FALSE
OnlyAccessHTTP=TRUE
Password=password
LogoffOnExit=FALSE
TrackLogon=FALSE
CheckACAccess=FALSE
RebootOnExit=FALSE
[Overrides]
ExitBrowser=
Logoff=
Shutdown=
ResetActvityTime=
ResetPrintLimit=
RestrictedSave=
ReReadINIFile=
OpenSysedit=
OpenRegedit=
OpenExplorer=
DisableProxy=
DisableFilters=
ShowAddressBar=
OverrideURLKeyword=
[Java]
JavaExit=
JavaActivity=
JavaRegister=
JavaHideToolbar=
JavaExecute=
JavaReadINIFile=
JavaPrint=PWBPrint
JavaLogoff=
JavaReboot=
JavaShutdown=
JavaHideAddressBar=
JavaPrintFrame=
JavaFillElement=
JavaOverrides=
JavaStartApp=
JavaSetActivity=
JavaGetActivity=
[ScreenSaver]
[Activity]
ActivityTimer=FALSE
ActivityWarnAt=120
ActivityAction=Exit
ActivitySoundFile=
[Proxy]
UseCustom=FALSE
ProxyEnable=FALSE
ProxyServer=
ProxyOverride=
AutoConfigURL=
[PageSetup]
UseCustom=FALSE
Footer=&u&b&d
MarginLeft=0.75000
MarginRight=0.75000
MarginTop=0.75000
Duplex=1
Orientation=1
[Buttons]
Back=TRUE
Forward=TRUE
Separator1=FALSE
Stop=TRUE
Refresh=TRUE
Home=TRUE
Separator2=FALSE
Search=FALSE
Favorites=FALSE
Print=FALSE
PrintPreview=Print
Separator3=FALSE
Send=FALSE
WebMail=FALSE
TextSize=TRUE
Zoom=TRUE
Separator4=FALSE
About=TRUE
Policy=TRUE
Separator5=FALSE
New=FALSE
Save=FALSE
Separator6=FALSE
Cut=FALSE
Copy=FALSE
Paste=FALSE
Find=FALSE
Encoding=FALSE
Popup=FALSE
Shell=FALSE
[MenuItems]
FileMenu=TRUE
FileNew=FALSE
FileOpen=FALSE
FileSaveAs=FALSE
FilePageSetup=TRUE
FilePrint=FALSE
FileSend=FALSE
FileSendFile=FALSE
FileSendLink=FALSE
FileExit=TRUE
EditMenu=TRUE
EditCut=TRUE
EditCopy=TRUE
EditPaste=TRUE
EditSelectAll=TRUE
EditFind=TRUE
ViewMenu=TRUE
ViewToolbar=True
ViewStatusBar=True
ViewSeparator1=TRUE
ViewGoto=TRUE
ViewGotoBack=TRUE
ViewGotoHome=TRUE
ViewGotoSearch=TRUE
ViewStop=TRUE
ViewRefresh=TRUE
ViewTextSize=TRUE
ViewSource=FALSE
ShellMenu=FALSE
FavoritesMenu=FALSE
FavoritesAdd=TRUE
HelpMenu=TRUE
HelpPolicy=TRUE
HelpAbout=TRUE
ViewZoom=
ViewZoomLarge=Large
ViewZoomSmall=Small
ViewEncoding=TRUE
[ContextMenu]
OpenLink=TRUE
OpenLinkNew=TRUE
SaveTarget=FALSE
PrintTarget=FALSE
Separator1=FALSE
ShowPicture=TRUE
SavePicture=FALSE
SetWallPaper=FALSE
Separator2=FALSE
Cut=TRUE
Copy=TRUE
CopyShortcut=TRUE
Paste=TRUE
Separator3=FALSE
Encoding=FALSE
Separator4=FALSE
Print=TRUE
Refresh=TRUE
Separator5=FALSE
Properties=FALSE
Back=Back
Forward=Forward
Separator0=TRUE
[URLKeys]
EnableURLKeys=FALSE
[AutoRegister]
RegisterSeconds=15
RegisterDaysLeft=30
[TimeCheck]
TimeToActionDay=
TimeToActionNight=
ActionDay=
ActionNight=
MessageFileDay=
MessageTitleNight=
MessageFileDNight=
MessageFileWarnDay=
[KioskButtons]
Back=TRUE
Separator1=TRUE
Forward=TRUE
Separator2=TRUE
Stop=TRUE
Separator3=TRUE
Refresh=TRUE
Separator4=TRUE
Home=TRUE
Separator5=TRUE
Print=TRUE
Separator6=TRUE
TextSize=FALSE
Separator7=TRUE
ScrollUp=TRUE
Separator8=TRUE
ScrollDown=TRUE
Separator9=FALSE
Close=TRUE
[HTMLError]
- Participant
Also not an issue with it just using IE. Also did a fresh install on my machine and had it point to the server for the PWB lay or and worked fine
If PWB worked on your computer but not on another then it may be an issue with the computer and not PWB.Also not an issue with it just using IE. Also did a fresh install on my machine and had it point to the server for the PWB lay or and worked fine
PWB version 2.11.9 with your INI file on Windows 7 with Internet Explorer 10.0.
- yahoo2.png (150.73 KiB) Viewed 24110 times
- Participant
Could it be that we have pwb installed on our machines and then the Short cut is ref a network share.... Should we uninstall the pwb on a public machine. I have tried that and the short cut fails out
PWB does not need to be installed as it is fully self contained. Whatever version the Shortcut is pointing to is the PWB version that will be ran.
- Participant
group policy "to help protect your security, internet explorer has blocked this website from displaying content with security certificate errors"
We get this at the top of the yahoo log on page.
If you right click on it you get the sub menu. Select "notification help" it opens up an IE browser, then you get get into yahoo and compose message and do the attachment. So I am thinking we may need to add something to our INI file to allow for the certificate to be displayed
This is actually an Internet Explorer setting.
If you adjust the setting in the Control Panel applet Internet Options for the user (this is a user specific setting) the Internet Explorer bar will not show as it is allowed.
http://answers.microsoft.com/en-us/ie/f ... c649dc0af6
http://www.youtube.com/watch?v=lCsIpb2hrJ4
- Participant
How about when you are using group policy for these settings
- Participant
I changed it in the Group policy management console under edit
User configuration/administrative components/Windows Components/Internet Explorer/ Internet Control Panel/ prevent ignoring certificate errors
It was set to enabled
I disabled it
I disabled it
- Participant
That didn't do it
