Page 1 of 2
PWB cef on-screen keyboard not appearing
Posted: Tue Apr 23, 2019 9:55 am
by bkasekamp
Using PWB cef and Windows 10 with a touch screen monitor, I'm unable to get the on-screen keyboard to appear when touching a text box in a website. When switching to PWB IE, or a chrome browser, the on-screen keyboard works correctly. Is there anyway to correct this?
Thanks, Brian
Re: PWB cef on-screen keyboard not appearing
Posted: Tue Apr 23, 2019 10:11 am
What version of PWB CEF are you using including the minor revision number, for example 3.05.4?
Posted: Tue Apr 23, 2019 10:14 am
by bkasekamp
PWB CEF Beta ver 3.05.5
Posted: Tue Apr 23, 2019 10:16 am
Try adding one or more of the following Chrome command line switches to the command line that starts PWB.
--touch-events
--enable-touch-drag-drop
--enable-touch-editing
--disable-usb-keyboard-detect
More information:
https://www.teamsoftwaresolutions.com/f ... 077&p=7569
Posted: Tue Jul 27, 2021 12:45 pm
by johnhibbert
I am using a Dell Optiplex 7480 AIO with a touchscreen. The onscreen keyboard pops up in every other application save PWB (CEF v.3.05.10), even after I add the command line switches (--touch-events --enable-touch-drag-drop --enable-touch-editing). These I added to a shortcut for PWB.
Am I putting the switches in the wrong place? even if I launch PWB through the command line, it still does not work.
Posted: Tue Jul 27, 2021 9:56 pm
Do you have PWB in Secure Mode?
Try using PWB with an unedited INI file to rule out any configuration issues.
Posted: Wed Jul 28, 2021 8:13 am
by johnhibbert
I suppose I shouls clarify; when I tap into the address bar, the onscreen keyboard comes up, but since we have PWB in kiosk mode (library catalog only), we don't have the address bar available for our users.
In our catalog, Google, or any other website that has input fields, the keyboard does not come up.
I tried it with an unedited INI to no avail, as well as booting in secure mode.
thanks,
- john
Posted: Wed Jul 28, 2021 11:56 am
If there is a physical keyboard attached to the device try removing it.
Posted: Wed Jul 28, 2021 1:20 pm
by johnhibbert
I have removed it, also restarting without the keyboard present (as it would be when I release it into "the wild"). It still seems to behave the same way.
- john
Posted: Thu Jul 29, 2021 12:46 pm
by jbush
I have this same situation. CEF 3.05.10
Posted: Thu Jul 29, 2021 3:30 pm
Does Chrome work as expected?
Posted: Fri Jul 30, 2021 6:03 am
by jbush
Yes, it does. I am using kiosk mode to display a reservation station. When I use it in any web browser the touch screen displays the keyboard. When I open it in PWB the keyboard will not display.
Posted: Sun Aug 01, 2021 11:20 am
Please send a copy of your INI file as an attachment to support @ teamsoftwaresolutions.com
Posted: Thu Aug 05, 2021 9:59 am
Adding the following to the command line that starts PWB can fix the On Screen Keyboard not showing in certain circumstances.
Posted: Wed Jul 27, 2022 12:27 pm
by lconn
Can you please tell me where to put this code in? I know this is an old post but having the same issue and don't know where to put the information you are referring to?
Linda
