Google.com won't load
Posted: Fri May 19, 2017 3:35 pm
by JGonzales55
Hello all,
It seems that if I try to go to "google.com" it will not loading when being input into the address bar, regardless of what render engine I am using. It does work if I do "https://www.google.com". It works in CEF with "www.google.com". If I try to go to a page such as "yahoo.com" or "purple.com" it will load without a problem in both engines.
Any suggestions?
JGonzales55
Re: Google.com won't load
Posted: Sat May 20, 2017 3:42 pm
Typing "google.com" into PWB does work with an unedited INI file.
What version of PWB are you using including the minor revision number and rendering engine, for example "3.05.0 CEF"?
Are you using a URL filter that is blocking the site?
Posted: Fri Nov 30, 2018 3:11 pm
by JGonzales55
I made this post so long ago and don't honestly remember why I was having that issue but it is resolved. I apologize for not following up.
