When a New PWB Window is opened sites are not compatible anymore.
Posted: Fri Jul 22, 2016 5:45 am
by Rockhard
We currently are using the PWB CEF 3.0.5k, and I have some sites setup to open in an IE Tab.
However when a site in the IE tab, goes to open a new window (say with webmail when you go write a new email) it opens a new PWB window.
Can you confirm when that new 2nd PWB window opens; is it still using compatibility mode and opening it in an IE instead of CEF? We are having applications not working in that new 2nd PWB. However if I force it to open in the parent window instead of a Second Window the page opens correctly. However then we have a different set of issues, since again in webmail if they go to write an email and send it then closes the entire tab.
Re: When a New PWB Window is opened sites are not compatible anymore.
Posted: Sat Jul 23, 2016 12:49 pm
The IE Compatibility Mode is an all or nothing setting. Once PWB starts with a specific Compatibility Mode set it will remain in the same mode throughout.
Do you have the same issue if you run PWB 3.05.0J IE with the same INI file, or with the unedited INI file?
