Ctrl+Alt+Delete Not Suppressed in SecureMode
Posted: Fri May 03, 2013 10:12 am
by GregD
I am working with PWBv3.03.4. I have enabled SecureMode in my Ini file, SecureMode=True. In the description of Secure Mode it stats that it will suppress Ctrl+Alt+Delete. However, when I am running PWBv3 and I press Ctrl+Alt+Delete I still get the menu associated with that. Are there any other steps I need to take to make sure PWBv3 runs in SecureMode?
edit: I'm working with Windows 7, if that makes any difference.
Thanks for your help,
GregD
Re: Ctrl+Alt+Delete Not Suppressed in SecureMode
Posted: Fri May 03, 2013 9:47 pm
Secure mode suppresses access to the Task Manager via the Ctrl-Alt-Del. Unfortunately it is not possible for an application to suppress the Secure Attention Sequence (Ctrl-Alt-Del) by design for secure measures.
See the following post about information on disabling the individual buttons.
http://www.teamsoftwaresolutions.com/fo ... ?f=1&t=412
