Disable CTRL + O
How can we make our software better?
Gerri
Disable CTRL + O
Post by Gerri »
I don't know if this has been mentioned before, or if I'm just missing it, but it would be very helpful if you could disable CTRL +O.
-Gerri
spragers
Benefactor
Benefactor
Post by spragers »
I believe if you disable the File menu "Open" option, then that will disable the corresponding keyboard shortcut.
Gerri
It worked!
Post by Gerri »
Yeah! You guys rock!
-Gerri
User avatar
Johenyst
Participant
Participant
Disable CTRL O
Post by Johenyst »
Hi
anyone have time for a question from a newbee?
How do i disable ctrl-alt-del on W2K or NT?
The built in command in NB 4 doesnt work with either.
Thanks in advance
/JT
Hello there ,
You Cant disable the right mouse click in WinNT and Win2K and Probaly WinXP.
and the reason why is Because Microsoft, decided that it should be done. so Neosoft will not be able to help, on that issue, no can actually,. and the only way you can disable the rigth mouse click is by creating a New KeyBoard Driver that Hooks to the Keyboard before the Kernell Does which will require istallation and rebooting the System.
so i Dont know who would take the time to design you the driver because it is not an easy task.
jay.
Thomasfab
Post by Thomasfab »
From what I understand you can already Ctrl-Click multiple items and do a Transfer Some. I know Jey discussed it, maybe he hasnt implemented it yet...
