Page Setup settings
Page Setup settings
Is there a way to have the Page Setup settings reset after the browser is closed? We have patrons who change them to remove the date/time stamp, etc. I don't think we want them locked out completely but we would like them to revert to the original settings when the browser is restarted.
You should be able to use the Page Setup section of the INI to set defaults when the browser is started.
;[PageSetup] See page set up dialog ? for help.
;UseCustom=False Force settings
;Footer=&u&b&d Print footer format
;Header=&w&bPage &p of &P Print header format
;MarginBottom=0.75000 Bottom margin
;MarginLeft=0.75000 Left margin
;MarginRight=0.75000 Right margin
;MarginTop=0.75000 Top margin
;Duplex=1 Duplex option: 1=None, 2=Flip on long side, 3=Flip on short side
;Orientation=1 Orientaion option: 1=Portrait, 2=Landscape
The only thing that may not work is the orientation. The orientation setting in IE was changed in IE 6.0 to default to the printer default setting.
